antonio costa
- Portugal
Mine will sit for a month with the jaws open and don't need zeroing upon my return.
Paid 40 quid second hand from someone on here last year.
Well worthwhile
Glad you're happy with them;-)
Well worthwhile
I’ve used mitutoyo manual verniers for years while my dad has gone through god knows how many digital ones from £15-50.
Could of bought a pair of coolant proof Mitutoyos the amount he has spent.
My eyes are not as good at picking out the lines anymore so I need to invest in a set.
Am I the only one to say it or even think it.Does anyone have a set of these?
Used mine today what a pile of poo!
Is it just a dodgy set I have?
They turn on if i tough them, the measurements are weird sometimes it measures a iter at 116mm them again at 120mm I think they are going back. The lidl ones are the nuts compared to these
https://www.aldi.co.uk/workzone-digital-caliper/p/097103241291600
I have found that they work ok, and not too bad for accuracy, but do not like being left in garages/sheds etc, where they are not impervious to damp atmosphere,
They're no more accurate or repeatable than the Workzone, but they have a much nicer feel, and they actually turn off so the battery life is pretty good.Don’t buy them unless you need them to be coolant proof.
they will be for use on the lathe so coolant and oil prof would be bennificialDon’t buy them unless you need them to be coolant proof.
Yes they are better quality because they are built to keep coolant out but if your just wanting a quality hard wearing set with spot on accuracy and repeatability then the original digitals are perfect
If you plan on covering them in coolant then yes the extra £40 is a worthwhile spend. I’ve just got the standard ones. Mine are old as they were made here not Japan.they will be for use on the lathe so coolant and oil prof would be bennificial
Just get Mituotoyos. Don’t muck around with anything else. They are the world leader in digital metrology.
I’d get the coolant proof ones, only because they’re even better made than the standard ones.
