The Jantsa 675128 are 0ET (offset), 6x205 PCD and have a centre bore of 161mm.
They’re rated to 2750kg.
But, I can’t help with a supplier![]()
Probably but I will just go with the custom build from aspectwheels. Unless bigtyres finds an answer.
Trouble is cost. Custom wheels are £145 each. Lorry tyres the same. So I am looking at about a grand in total for 3 wheels and tyres!
How much was the trailer?
The 15.3" rims I got from Big Tyres were from Jantsa, so if Jantsa make them Big Tyres should be able to get them![]()
These guys list 17.5 wheels and tyres
https://www.meredithandeyre.co.uk/images/Components-PDF/Wheels-&-Tyres-Oct-12.pdf
I gave up with avonride when I was trying to deal with them as they were just plain stupid.
try these guys.https://www.autow.com/products/trailer-parts/suspension-axles its who I ended up getting some custom axles from, they seemed pretty clued up.
id hate to see what 3500kg rated single axles ride like unlaiden.
After speaking to Big tyres who were very helpful it looks like I will have to have them custom built. What a crazy situation.
Yes they said they didn't deal with them which I thought a bit odd.Did you mention the Jantsa 675128 part number to them?
It is a 3500kg axle. The wheels on it apparently for delivery purposes only. It is designed for much bigger wheels.Fitting those bigger tyres/wheels is going to reduce the braking efficiency a fair bit.
Bob
Very odd, seeing as the two wheels I just bought from them have Jantsa stamped on them! Maybe they bought them through someone else?Yes they said they didn't deal with them which I thought a bit odd.
