Guy won’t paythat kind of money so it’s in steelThe zinc will wear off sliding parts eventually, I'd make it out of stainless
It’s an Ali body made of 3mm sheet it’s not going to see any real loads, sure the three 20mm hinges will be fine.rust yer,but wont seize if in regular use i'd have put a couple of more holed brackets on it though between centre and ends
That's going to rust and seize - never mind the slightest kink from dropping something on/against it jamming it or making it stiff.
En8 ain't that tough !I very much doubt that mate. It will be used fairly regularly so won’t seize and is made from EN8. Not your standard S275 that bends easily.
A lot tougher than S275.En8 ain't that tough !
As for zinc plating they likely won't take it incase it carries them between baths ,you would also get it back with steaks of rust where the chem got but not the zinc .
It's also good at finding poor restarts in welds in the last regards and all welds must be full
Hey just talking from practical experienceA lot tougher than S275.
Bout 300-400MPa yield mate in the rolled state.
I’ve got a test cert somewhere.
It’s looking like playing isn’t going to be an option then.
