thanks for help. The Aldi setup does sound really good. So i will get a 48L tank with 18.6cfm. thanks![]()
I used one of these & no complaints for a cheap gun:
Ran it off a 50L compressor
Will be noisy though is the only real issue.
I would imagine you can probably can get different sizes, But personally I didn't feel the need to change the setup it comes with. Air Pressure & cleaning the gun after use are quite important.Nice, how isit finding different tips for these guns? or are they fixed to one size?
Its just a cheap 50l compressor, Nothing fancy. Higher capacity the better with air tools. I don't use it for anything other than, inflating tyres, blowing things off & using the paint gun.What air compressor setup are you using to run your spray guns?
Looking to keep them out the way, about 60ft away. Isit the motor size (HP) that determines the CFM rate?
I have two 50l 14.5cfm direct drives and a 90l 14cfm belt drive.
