What is the small connector?Today I made my life easier, I fitted an interlocked switch socket to the wall which my Stealth Tig will plug into. It will save me having to reach round the back to the far side to switch it on and off.
That wall in the workshop is a nightmare, it is made of sea bools (mainly quartz) and is almost impossible to drill but eventually I managed.
I also fitted a small socket into the box which is wired into the L1, N and Earth at the back of the socket. It now means my wall bracket tig cooler will also come on when I switch it on and if at any point in time I don't require the cooler I can just unplug that.
It is for the water cooler which is integrated into the wall bracket.What is the small connector?
Today I was chopping and hacking up the roller system I removed from the 7m cat to make it fit the 10m one.
And me such a God fearing peasantTsk, tsk....working on the Sabbath![]()
A bit of tin work not today but last weekView attachment 160799
Much prefer it to timber now, walls are straight with no shrinkage and popped plasterboard screws
)from the loops in the container that are meant for securing the contents and the sheet is pulled up onto the table. Normally I just get a hand and two of us man handle stuff on but the heaviest prior to this was a sheet of 5mm 316 and I knew from that experience that 8mm steel wasn't happening
Is that an office or domestic build - any welding involved? Genuinely curious, not something I know anything about! I'm guessing domestic looking at what seems to be a shower tray in the background...
Not a fan myself. Feel far too flimsy and no good for load bearing.metal stud walls are far better than wood and faster to put together once you have done a couple. all done with self drilling screws ive worked on a few buildings done out with them
