yep that's what I do works a treat put a jubilee clip on it thoughput a bit of rubber hose on stem of valve and pull backwards while other end is in a cordless drill
Well that's gonna be yours truly and I'm defiantly a novice (at best) so any and all advise very gratefully received, thankfully it's a single cylinder engine so only 2 valves to do. Mind you I have a Rover V8 that also needs doing at some point in the future so I'll have plenty of time to improve.It's not the quality of the paste that's important, it's the quality of the apprentice that you lumber with the job of grinding them in![]()
Yep that's the way I was thaught to do it too. Proper valve lapping machines work like that also.Presume if you’ve recut the seats you’ve refaced the valves as well so only use the fine paste . Not a fan of spinning valves with a drill, when I was learning it was a “ hanging offence” ! Put a light spring under the valve head so that it lifts the valve off the seat. Twizzle it back and forth, allow it to lift , quarter of a turn and twizzle again and so on. That way you don’t get tramlines round the valve and seat. Proper job.
An old boy I worked with argued that paste was a waste of time, he reckoned the paste held the valve higher on the seat and the second the paste was not in there the valve dropped down onto an unground surface. He reckoned stone the valve and seat to the correct angle and fit/forget. I still lap valves but when doing it his words echo in my empty head
Bob
That's an interesting theory but not sure about its validity.
He’s right about the no lapping of new engines. Whether all new ones , I don’t know, but certainly Briggs and Stratton don’t . Another interesting thing that came to light re Briggs was the setting of valve clearances on side valve engines . Guess that they are robot assembled now but when hand assembled the op had a rack of valves with fractionally different length stems and selected ones that gave the right clearance. In service we have to grind the end of the stems to restore clearance - rather crude!He worked at the RAE Farnborough as a mechanic building aircraft piston engines so should have known his stuff, he also went on to say they dont lap valves in on new engines either so I suppose he has a point. If all the angles and machining are correct its unnecessary. But I still do it
Bob
