That's an excellent video.
Is it the act of running the neutral to the star point that causes the motor to generate 415v? That's a novel approach that I never heard of before.
Looks really good and well executed. However I don’t understand how it works. Doesn’t the motor need to be driven by another motor ?
You are confusing that with a balance motor setup, where a secondary motor is running all the time, I believe it was to smooth out the load
Each phase winding in a 415v 3 phase (star) motor will have a nominal 230v across it, so once connected in star you are simulating that condition. You end up with a neutral that is floating above ground which you need to be aware of.
Thats what i am trying to get my head around, spent 20 years around various phase converters. Supply looks very light gauge cable on the 16 amp plug, i would expect big volt drop on start ups.I would have thought you would need a big idler motor though as you are pulling a lot of current through just one set of motor windings on the 240v supply in.
How do you adjust capacitance for differing loads/machines ?
