Brass does conduct better than brass, but I honestly think you wouldn't notice enough of a difference to be concerned with.
Hi guys helping a friend replace the brass connector bolts on his oil cooled welder. We cant find brass bolts around here. Could we use stanless steel bolts.[/QUOTE
How about a ship chandler
They will probably be whitworth
Might be easier to get some one with a lathe to knock a few up from hex bar
yea if u take it to bits , crane the transformer out of the can . oil all over the wires are solid copper bars inside . open the holes out fit plugs is it really worth itCould we put a dines socket to replace them . I know they would be facing up
Do you know anybody with a lathe. Hex Brass stock available on the bay https://www.ebay.co.uk/itm/Brass-He...al-sizes-3-8-1-live-steam-model-/231489296627. Get some replacement bolts made up?Hi guys helping a friend replace the brass connector bolts on his oil cooled welder. We cant find brass bolts around here. Could we use stanless steel bolts.
no need for a lathe u can do them on a pedestal drill if your pushed
studs fit through oil cooled welder and lugs just fastened on with a nutEven if it's the bolts he needs?Nuts'd be simple, but for bolts wouldn't you just cut a thread on brass rod ......?
u may be rightAh, I read it as he needed to replace the studs.![]()
Hi guys its the bolts .all the treads are striped
