If you find a raster you need converted search for vector magic they have stand alone and online versions. Fully automated or you can adjust what you need to convert them.There are online free tools that will do it. Not all pdf files are vector - you may come across one that is a raster pdf, in which case it gets complex, but, for vector pdfs, just one of the free online things will, I'm sure, do the job for you.
Probably so you cant alter the drawings easily without converting , but allow you to read or print them.Thanks for posting that question, I had no idea you could do that.
Had a quick look online and it all looks pretty straightforward .
Had architects in the past who have refused to send DWG version of their drawings (god knows why) , so at least there is now a work around
Mcdavid, if someone modifies your design and the modification causes a problem then you would not be liable. Though there could still be a legal battle as you try to prove if the fault was due to the modification or due to the part of the design your company did.Can't speak for your architects, but it's a common practice in engineering, we won't send you natives files of anything. Several reasons, most importantly is that we're legally liable for the design, and if you only have a pdf copy, you can't change anything without our knowledge, it avoids design changes etc, which they can not be held responsible for or endorse. Basically self preservation / legalese.. other reasons include commercial, we do the work, and you go somewhere else with our design, etc...
certainly I won't send anyone any natives formats, only PDF, up to and including approved for construction, then at the end of the contract, we'll provide you with all the as built docs in native format, after official handover / acceptance.
Trouble with source code if that the developer has usually invested time in code which he then re-uses on many projects to get them done quickly and competitively. Developer is then handing that code over and it could be obtained by his competitors. There's also licensing issues, if a developer is reusing code and handing it to clients then who owns it.I suppose it's the same if you write bespoke software, I'd be happy to supply flowcharts but never the source code unless that was pert of the agreement, and only then once I'd been paid!
@MCKDAVID and @rtbcomp what do you guys do then?
