I hope to try out each of MIG, TIG and Arc welding on some scrap metal before I go anywhere near a rusty old panel on my car. I came across this old side plate from a lawnmower. The steel plate is no thicker than car bodywork and might be a realistic panel to practice on. Another bonus is that it's well-rusted, especially on the reverse, just like a typical old car wing or sill panel. I will cut out small sections and weld in some new metal plates: (1) MIG (2) TIG and (3) Arc although probably not in that order. It will be interesting to see how the three patches compare.
QUESTION: for this to be a realistic practice piece, should I de-rust only the front of the panel, as you would certainly do on a car, back to bright steel. Or should I de-rust both sides? On a typical, average car repair are you normally able to get behind the panel which needs a patch, in order to de-rust it?
UPDATE: in reply #3, TIG Paul very helpfully pointed out that my lawn mower plate is "a pressing so apart from the rust the material may not be an ordinary mild steel, and won't give you the experience your looking for." I'm sure he's right, so I won't be using this sample, after all. I will look for some rusty old metal off an old car, instead.
) so make sure you clean it right off and get a really good earth.
This is what happened to me and although I've been welding (amateur shed/garage based stuff) for quite a while I'd never welded car bodywork before but I managed to change both sills after having repaired the inner sills and got it thru the MOT.The MOT man commented on it being repaired to a good standard which is down to the advice found here,having a look at how others tackled similar jobs and some practice.Read through Malcs tutorials,they're excellent,especially the "welding thin metal" one.Then having read those have a read at some of the restoration threads on the Turbosport forum for inspiration as to what can be "saved".No amount of reading though is substitute for getting in the garage and having a go.
) the patch and punching holes in the edge of the original panel
