@gerrymoore perhaps?There was one member who did this, I seem to recall he had no end of grief but got it working eventually... I forget who it was![]()
, got there eventually!I've known a few people make cnc things (not just plasma).
The ones who simply wanted a finished tool to use complained about "endless problems".
The ones who did the build for itself (having a tool at the end of it was almost optional) had the same issues, but called them "interesting challenges" instead![]()
I do see it as a challenge, no experience in electrickery so ideally a kit with the correctly spect motors and software would be good. There's a lot on eBay but need to research what NEMA means and what I need. Just started looking but it is going to be my next project .
Anyway not trying to put you off the idea just consider what you want it for. But it is fun when it works.
I can confirm 'IT IS FUN WHEN IT WORKS'. I agree with all the above posts and you don't really need and indepth electrical knowledge, but some is very usefull. I completed mine about two years ago and it was an absolute achievement watching it go. It was a far more daunting and frightening prospect watching it cut something. The hardware is the simplest to get your head around, I built mine in three weeks with no plans. Just started at the smallest component 'the Z drive' and went from there. Integration of the electronics package (control system and software) is what rattled me and I nearly poured petrol on mine several times. The control package (electronics, drive systems and software) all came from the states, as I wanted the minimal problems in getting one going. If 'everything' is able to communicate with each other and run together, then it is just a matter of plugging it all together and it goes
Nothing is quite that simple as the combinations of drives are endless.
You need to decide what it is that you really want and or need. See what is out there in the market in turn key systems and of you feel you can build one then go for it. Remember your build needs to be accurate and you need to be annual in doing so. I build my machine to plasma cut, route timber, plastics and flat bed mill alli, so very specific requirements in a build. So far it has played the game and the only problem I have had was a faulty operator unit, the organic controller. I know enough in the software to get by, but not enough to get the maximum out of the package, but it has all worked for me. Once the job is done, then you move onto the next. There isn't time to 'how can we make this better' if there was large production runs then I would look at everything again, but most of my stuff is one off's, two's and possibly three.
Morning, just a few of my thoughts on accuracy after reading @henry Kadzielski 's response, these are my thoughts and that only that, I am not getting into argumentative mode and disagreeing with Henry about designs.
When routing and milling you design with Rigidity and accuracy in mind. There is side loading on the the cutters, power is needed to push the cutter through the material at speeds and you may well wish to have accuracy down in the region of 0.05mm (0.002") depending on the final application of what you are cutting. Plasma is not accurate to that degree because of the process. Have a read of this manufacturers paper.
http://torchmate.com/white-papers/The-Accuracy-of-Plasma-ARC.
Also when milling/routing the travel speeds could be mid to high, but I believe not as high as using say a 40 amp cutter on 22 gauge sheet. where best results for 40 amp cutters could be over 8 metres per minute travel speeds.
http://torchmate.com/uploads/downloads/metric-measures/FineCutwithLowSpeed03_12.pdf
There is a general direct correlation of speed and location accuracy in the driver units, steppers and servos and is down to step distance per pulse, the smaller it is then the slower the top end speed is as the motors will have a finite rotational speed.
Because the plasma is not as accurate a cut process the step distance per pulse is typically larger than for milling or routing and allows for a higher travel speed, there is also no side loading on a plasma torch, the issue is more the initial inertia of gantries/carriages to get over when trying to move at high speeds.
All the above is really just going off how my brain works and what I have picked up as I go along.
I feel chuffed when I cut out parts like the tea-light and name monograms. My gear is really down at the low end of the scale.
Adrian
View attachment 119257 Thanks for all the input guys. Started researching rail systems and as I'm on a tight budget tried this experiment.
It is surprising how smooth it is but will have to use better metal for the rail on the real one.
Have a video of it.Why?
Some of the ones I have seen in kit form use ERW tube and sit them on edge similar to your idea with angle. You could flap disk it down if required, but, you said it is smooth, how many thou do you think it will deviate the cutter with the mill scale?
Adrian
