KemppiFrog
- Aquitaine
Hi all
My venerable Espace has developed a problem. Happened from one day to the next. Starts, but idles with the accelerator pedal having no effect. So I engage first gear and get moving, change to second and when it is going a bit faster, drop to first, when it revs to over 1000 rpm and responds to the accelerator. Not too bad if around open roads, but a pig in traffic, as I have to heel and toe to keep the revs over 1000.
Now I know how the pump works and have looked at some vids on Utube about stripping the unit. BUT, does anybody have an idea of what might be the cause? Natch, one hopes for a bust spring, or some other minor bit.
Engine is the 2.1 Turbo diesel with 'old tech' pump and injectors from '96. Now banned from central Paris as too sniffy.
KF
KF
. So, the fuel pressure is too low to accelerate, but once it turns a bit faster, it raises the pressure enough to supply the high pressure section? If that is the case, then stripping it is probably not worth it. The local scrappy has one at €150. Not cheap by UK prices, but fixing the current one sounds more, if you are correct. Octo's idea might overcome it on a temp basis, for not much effort, as well as proving the point. Bit busy at the mo' and don't want to take it off the road, plus finding parts is a prob here.
, but no wizzy sounds or clicking when turning on the ignition).
