hi, i have an old Eland 160 amp mig i think the wire speed is to fast even set at zero on dial it seems to feed to fast and possible to slow set at max speed, is there an approx amount of wire per minute. It seems to be okay to use on power setting 5 or 6 with wire dial set to almost zero for thin car body panels, using 0.6mm wire. i am using only co2 gas from local bar suppliers or should i use argon mix to weld thin stuff. thanks Marko
