Hiya,
Changing some plumbing ready for the new kitchen and need to change the layout of some pipes.
I have 4 pipes (H/C and Radiator F/R) which I want to run down the side of a vertical brick pillar then turn at skirting level to run along the wall which is at 90 deg to the pillar.
So, I was thinking that this will require a simple 90 deg bend for the 1st pipe but then a bend and also a twist to the 2nd, 3rd, 4th pipe to make them flush to the wall.
Is this a practical approach or would I be better to just run the 4 pipes vertically up the wall next to the pillar rather than trying to run them up the side of the pillar itself?
Cheers,
MM
Cheers,
MM
