This started out as a caravan (rolled). I cut the chassis down to 4 foot and made a bed 8x5. I then after carefully positioning welded a length of 3x6x1/8 channel between the chassis. I made a frame for the body from3x1 1/2x3mm box and 50mm angle and welded this to the chassis. The A frame then shortened and clamped to the body positioned up to the channel, and after checking that all was square to the axle welded in. the rod to connect the brakes was shortend and welded together, the brakes adjusted and she is ready for lights mudguards and lights.
