lol very bad indeed, only last portion weld, first and middle just blows holes. I guess i must get copper backing and thinner wire to try this again later, stainless backing just dont do it.
You'll never weld blades together with rod, unless it's as thin as the blade itself. As you will need far more amps to melt the rod than the blade, hence the mess.
Try it without filler and the blades at 30deg angle, arcing up off the blades, then running straight across
