hermetic
I have done Part P work which gets inspected by the local councils elec building inspector (for a fee of course) so you can do it because your training shows you are a "competent person" TBH filling the form out is much more onerous that the installation is difficult! In reality little has changed in the basic domestic wiring situation, apart from the (now reduced) requirements of part P of the building regulations and many of the IET tables are lifted from the IEE books (you can tell by the typeface!) You are right about RCD's, and people were killed in the days when they were not fitted to lighting circuits, the problem is, what happens when the electronics inside the RCD fails, but the RCD remains in the on position? RCD's and MCB's do NOT fail safe, which is why the IEE regs used to state that "No mechanical device shall be fitted into any installation as a SOLE means of protection against overload and fault current! In other words, you use a fuse as well as a back up. So if the MCB/RCD fails, as it will if it is slow cooked by a loose connection in one of the pressed metal clamp style steel terminations in modern CU's, the next level of protection is the 100A fuse in the cutout! that is why consumer units are catching fire, a phenomena unheard of til very recently!! Also the CU's were made of inflammable plastic, as opposed to non flammable phenolic, like the old Wylex units were
I have the National diploma in Elec engineering, the Elec inspector had the Higher National diploma, extra year at college, which they wanted me to do as well, but the slide rules were doing my head in, an electronic calculator cost £60 and I was earning £14.00 for 44 hours! I started in 1967 doing 44 hours for three quid a week, and had to go in on saturdays mornings, when the bus fare cost more than I earned for the 4 hours! An if you told that to the kids today, they wouldnt believe yer etc etc!
Phil
Phil
