Agroshield
The trials and tribulations of the SIP wire feed are well-documented. But I've not yet seen mention of something that caught me out today, and which contributes to the weak feed roll package.
The reel of wire is held on by a knurled screw and a spring, used to adjust the resistance of the roll so it doesn't unwind and tangle. As the manual suggests, the wire should come off the reel from the bottom, hence it rotates clockwise.
This clockwise rotation can lead to self-tightening of the knurled screw, increasing the resistance of the roll and causing wire-feed problems. This manifests itself at the tip as burn back, leading to the wire welding itself to the tip if you are not careful.
So. what I'm saying, is check not only your feed-rolls but also the reel if you are experiencing problems. I am going to try a couple of things to overcome this: install a thrust bearing between spring and reel or try a softer spring for the smaller reel.
