voteshanequinn
New Member
TEC-ARC MMA WELDING MACHINES New model
Professional 160A arc welding Inverter c/w leads & carry case
i found this similar tecarc to the 166i from the weld equip shop, has anyone heard of it or is it a knock off?
The MMA165i is designed for professional MMA stick welding and scratch start DC tig welding. The output power is variable between 20 and 160 amps and is ideal for for welding with 2.5 & 3.2mm rods with a max rod size of 4.0mm. Hot start is built in to allow easy starting of electrodes, just scratch the surface with the rod and it starts welding without sticking.
This machine utilises the very latest German IGBT inverter technology, which has resulted in a very powerful yet compact & light machine which is very electrically efficient.
This machine is robustly constructed in a strong steel case with the internal parts securely assembled to withstand knocks & small drops. A carry strap is supplied for easy transporting.
The MMA165i is generator friendly, providing a quality stable generator of 6KVA+ is used.
Built to comply with BS EN 60974-1, CE marked, RoHS compliant and WEEE registered so you can be sure of the quality.
We guarantee to fully support this model with spares & service for a minimum of 10 years.
The best back up in the industry!
Technical spec MMA 165i
Supply voltage 230V +/-15%
Fuse (slow blow)* 13/16A
Max (OCV) 56V
Duty cycle 160A@40%,130A@60%
Electrode size 1.6-3.2mm, 4.0mm max
Weight approx 4KG
Protection IP21
Approx. machine size 270*180*120mm
*Above 150A a 13A fuse may blow occasionally.
Max (OCV) 56V
Weight approx 4KG
Protection IP21
