Hi. I need to remove welded seam from inside a 1.1/2 3mm thick mild steel tube so i can slide a 1.1/4 tube inside it.
I can buy some cold drawn seamless tube but it states on the website that its hard to weld or needs a special welder. So im not sure if ill be able to use my standard mig.
Is it possible to remove this weld?
Ive found the correct size adjustable rimmer which looks like it would do the job but im unsure if it would be capable or removing the weld. The tubes only 5” long.
