C Cheesie Member Messages 1,097 Location Lisburn Aug 8, 2022 #1 Anyone know the preasure rating of the above pipe
T tigdlo Member Messages 870 Location UK Aug 8, 2022 #2 What grade? Heat treat? How are you closing the ends to allow it to be pressurised? Even with those answers I still won't know......
C Cheesie Member Messages 1,097 Location Lisburn Aug 8, 2022 #3 Closing ends with domed end caps 1.6-1.6 tube is 6082, I will double check grade when I'm home
M minimutly Member Messages 5,573 Location Pembrokeshire Wales Aug 8, 2022 #4 I’d be surprised if it has one. Not something usually specified for.
H hotponyshoes Member Messages 6,421 Location Somerset. Uk Aug 8, 2022 #5 You can work it out if you know the material grade and heat treat. The way you fix the ends on will probably be the weak point though so you will want to calculate that as well.
