SiPMerlin150
- Sunshine Coast, Queensland
Hello guys and girls,
I'm in need of some advice, specifically on the meeting the full power requirements of my arc welder. The power lead is less than a meter long, so from where its situated for use (in my shed) It's been drawing power from a 4 meter extension lead. This has been fine with no problems until recently when i turned the amps up to 3/4 of the way to try to sustain an arc on some 7018 rods, which it did, but after 5 minutes, the fuse in the extension chord crapped out. Replaced the fuse and im back to the lower amps with my 6013 rods.
I'm in need of a more suitable extension lead for my welder so i can utilise more of its potential. Here are my welders power information
SiP Merlin 150 - (Your typical 50v ocv transformer buzz box)
Min. welding power - 45amps Maximum - 150amps
Power 3.9kW
(It needs to be at least 5 - 6 meters in length)
Does the length of the cable affect amperage/voltage transfer, or would it be just easier to wire a new longer piece of heavy gauge flex into the welder unit?
Thanks in advance!
Power 3.9kW
Thanks in advance!
