Nomad
- North Devon (for how long?)
I recently collected a tidy Snap On 160 (rebadged Cerbora 838) with a known "low power" fault courtesy of a very nice gent @plewlandsbob
It works but the weld is very weak with a few very nice beads when it decides to work properly.
My next task is to find out why it keeps going into "very poorly" mode
Manuals and circuit diagrams are available which is handy https://welding.cebora.it/en/assistance/items-out-of-production?b_start:int=240
When I checked the voltages they are stable but a lot lower than expected.
Actual readings are 18v-29v but spec says they should be 29v-44v.
Tests were done with no load, pressure off the feed roller, I measured at the bridge rectifier output just to remove any problems due to bad joints on the earth cable etc.
I tried measuring the AC into the rectifier but I need to recheck.
Should voltages be about the same when I compare AC-in and DC-out ? (so if I have 35V AC it should show about 35V DC out) ?
The bridge rectifier looks to have 16 diodes (8 on the top plate, same on the lower plate).
They are solderer in sets of 4. Without cutting them out of the circuit, is there a way I can measure them individually to see if any have failed ?
If the rectifier turns out to be faulty, is it difficult to make a new rectifier using standard power diodes? 70HFR120 / 70HF120 seem very common but are they suitable?
A pack of 20 diodes ( 10 forward + 10 reverse) are a fraction of the cost of a new rectifier
Any suggestions for other - cheap & common - diodes if these are not suitable ?
Earlier threads with tests that I'll look at next time :
Faulty power selector switch https://www.mig-welding.co.uk/forum...ig-187-low-on-power.95599/page-2#post-1435395
Check and remake high voltage connections https://www.mig-welding.co.uk/forum/threads/snap-on-pro-mig-187-low-on-power.95599/#post-1429084
Tests for power loss https://www.mig-welding.co.uk/forum/threads/snap-on-pro-mig-160-power-fading.116789/
All suggestions will be welcome so fire away !
Many thanks.
Many thanks.
