oooooooooooo very tempting.
dont suppose your into motorbikes are you. got a tt600r 53 plate that i am selling i want 1200 for it but it will be going on the dredded ebay when the mot is passed next week.
i have been told thats its gonna fetch more, we will see
anyway if the welder hasnt sold after i have sold the bike i may be willing to throw some money to ya for it
ohhhhhhh very very interesting........ is it 'like new' still? and do you have a foot control too?... and your fairly local too.... do ya take plastic...!! seriously tho give me a pm/ ring if your seriously thinking of selling... i'm seriously think of buying...!!
Sorry guys, the updates are not coming through in an email update..
The spec is:
Portamig TIG 206i
Inverter range of welding machines
A heavy duty range of professional inverter welding machines designed to give the best performance in the industry.
They all have the following features; 60% duty cycle @ 40 degrees @ maximum output current, very high efficiency so they use less electric than most and all will work from a 13A plug*, excellent welding performance with a very stable and quiet arc, large 35-50mm connectors. The machines are robustly constructed with all internal parts mounted in such a way as to prevent damage caused by small drops which is a common problem with many inverters, the power components are rated to give a large safety margin for the best reliability and importantly these machines are easy to work on and always repairable should a fault occur outside warranty. All models are built to BS EN 60974-1 and are CE marked.
This machine is designed for high quality AC & DC TIG welding & MMA stick welding. The machine is fitted with the following; HF to start the arc, Infinately variable output between 5 and 200 amps, pre & post gas, slope down, torch trigger latching, built in pulser with variable freq, base current & pulse width, true AC squarewave with balance to control arc cleaning & penetration, digital ammeter, arc force on MMA, remote socket for foot control etc.
Technical spec TIG 206i AC DC
Supply voltage 230V 50/60HZ
Fuse (slow blow)* 13/16A
Max no load voltage (OCV) 80V
Duty cycle 200A @ 60%
Size approx 520Lx370Hx320
Weight approx 24KG
Protection IP21
Comes with:
Welder
All torch leads
Disposable regulator
Normal regulator
Decent welding helmet
Decent gloves
Few disposable argon bottles
A few tips/tungstens/dipping rod suitable for ali, stainless and mild
Whole package cost me about £1200 over xmas, only used it about 4 times, so in excellent condition.
I'll even throw in my self made welding top
Comes with 2 years warranty
