Hi everyone
i have been given a migatronic mx5000 and i hope to learn basic mig welding using it,can anyone tell me what amps it"s rated at and if i can weld 3mm mild steel box section with it using gasless 0.8 wire
thanks
bullgoose
I acquired a 5000MX a while ago as a non-runner and intended to fix it, but also bought a Cebora which I've been using instead.
Your post has prompted me to get the machine running again as it apparently goes right down to 20A http://www.mig-welding.co.uk/forum/showthread.php?t=1223
Hi Folks.
Sorry, it’s been a long time since I was last on the forum. I still have the migatronic but had to put my plans to use it on hold until now. My plan is to buy and fit a Euro Torch Conversion to replace the worn out parts on the machine, so that while I’m learning to weld I can rule out any problems with the free running of the wire and just put the bad welds down to me.
Could I ask the forums advice on what I need to buy (Are there different types of euro torch for example) to make this conversion and from whom to make the purchase.
Cheers
Bullgoose
