Hi all
I'm new to this forum so here goes.
I've recently bought a Migatronic 166 Rally Welder it welds a treat with 0.8 wire in it and i'm happy with my purchase apart from 1 issue.
When i weld on the highest setting it doesn't seem to take long before the temperature light comes on and the welder shuts down
. There is no fan fitted in the welder I assume this is not a factory fit item on this size welder?
This may be normal but I doubt it as it does the same on a lower power setting, is there anything obvious I could check initially?
Thanks
Colin
. There is no fan fitted in the welder I assume this is not a factory fit item on this size welder?This may be normal but I doubt it as it does the same on a lower power setting, is there anything obvious I could check initially?
Thanks
Colin
