Jan-DIY Member Messages 774 Location Lower Saxony Germany Jan 20, 2021 #1 Hi all. Got this machine send over to have a look at it. SMPS TOP245 shortet out. Replaced and now i got Error E07 message which is not mentioned in any manual i got. Anybody know this kind of Error?
Tangledfeet Think outside, no box required. Messages 3,073 Location Top of a hill above St Andrews, Fife Jan 20, 2021 #2 Perhaps @matt1978 might be able to assist? @Jan-DIY He is the person behind Lorch in the UK - just in case you were wondering!
Munkul Jack of some trades, Master of none Messages 7,382 Location Cumbria Jan 20, 2021 #3 From the T-pro manual (so MIGHT be different codes, but i doubt it) E07-2 EEProm error E-assembly defective Inform Service E07-0 EEProm checksum error E-assembly defective Inform Service
Jan-DIY Member Messages 774 Location Lower Saxony Germany Jan 20, 2021 #4 Hi, as i can see in T-Pro manual EEProm issue will show up in wire feeder unit. I think this is may relatet in PFC boost stage or primary inverter? Jan
Munkul Jack of some trades, Master of none Messages 7,382 Location Cumbria Jan 20, 2021 #5 Jan-DIY said: Hi, as i can see in T-Pro manual EEProm issue will show up in wire feeder unit. I think this is may relatet in PFC boost stage or primary inverter? Jan Click to expand... Sorry you're absolutely right, I hadn't noticed that the errors were TF-pro only.
matt1978 www.lorch.eu Messages 3,967 Location UK, Cannock Jan 20, 2021 #6 On the older software there was an E07 (described in the 2nd column) Here you can see a description from the service manual Can you check the cables as described
Jan-DIY Member Messages 774 Location Lower Saxony Germany Jan 20, 2021 #7 Thank you Matt! Will check. Keep you informed. Jan
Jan-DIY Member Messages 774 Location Lower Saxony Germany Jan 20, 2021 #8 Grrr. Got it. Or spot it. Traces on 2nd or 3rd layer vaporized. Try to discover other landing point. Somewhere on DC bus. Bad soldering anyway. 9F77AC5F-2CB9-4C4D-B793-705812117913.jpeg 307.7 KB · Views: 157
Jan-DIY Member Messages 774 Location Lower Saxony Germany Jan 27, 2021 #9 Got it back to business. Not that easy. TOP245 switcher, several copper traces, ceramic cap and finally feedback oc. thanks to @matt1978 to give me a hint to smps reasons. Jan
