Memmeddu
- Italia Sardegna
Think that can work fine80-100a torch is slightly overkill.
Pilot arc hack no problemswill not start the arc will 20a
Yes but the main arc wouldn't startPilot arc hack no problems
an 80a torch would usually have different hole sizes available to tailor the torch for your needs.even Chinese copiesIf lower ampage consumables are available. I have a 30a plasma, a Pt31 will work on it at 15amps on 1mm sheet, a sg55 with 40a consumables will not start the arc will 20a. The hole size in the 80a consumables will be larger wider cut and use more air,
Think is worth to try ,if goes bad I always have a rrplareplac torch for another plasma cutter (which i think to need 2 is always better than one only )Yes but the main arc wouldn't start
Only to a German address, unfortunately.Lads it’s available to order online on the website link above
Yes this is the idea use the smaller size of tipan 80a torch would usually have different hole sizes available to tailor the torch for your needs.even Chinese copies
Don't care about it is a plasma cutter ,is cheap ,is green and the lidl warranty is something of great so you have only to get apart the quantity of money to buy itThreads like this should be banned!
I was trying to justify why not to get a Plasma Cutter, But at that sort of price bracket I wouldn't say no
There is a path to get Lidl stuff out of GermanyOnly to a German address, unfortunately.
Would that be a Schindler lift?Is Schindler still alive?
In the UK? One of the earlier posts said for delivery only in Germany.Available to pre-order - orders won't be sent until the cutter appears in the shops.
