yes no problem just make sure there well cleaned and fluxed and u can get the heat up with a propane torch depending what they are . you might have to tin both surfaces 1st . flux and dab the solder on when held together unless you have a large copper soldering iron heated on the stovehi all im looking to make some small decorative projects using copper sheet and mild steel sheet, can i solder these two metals together? thanks in advance
