First post!
After some advice on my Ideal 120N. If the machine is left unused and powered off for a few hours, when you first try welding the wire speed has to be turned up quite high. Over the first 15 minutes of use I have to turn the speed controller down. I suspect that the liner needs replacing and given the condition of the torch I was planning to replace the whole lot. Do I have to buy a Euro torch and adapter or is there a direct replacement. How much should I expect to be spending on teh torh and liner. I also need a new regulator so was after some advice on something of reasonable quality.
Thanks
Rob
Thanks
Rob
