Ha... One day they will be mTe at mo though want to practice it.. For laters... XDucati pipes Noods?
Arrr yes I have one of those .. So like that you would need 3 of them to make the 90 degree angle you req yes? Xif you have a cut off saw you can use that, so if you were using a 30 degree angle on the pipe, you'd need to set the saw to a 15 degree angle, cut the tube, then rotate the pipe 180 degree, and then cut the pipe to length and that would give you the 30 degree angle for one of the sections
I read it upside down and it made perfect sense to me... XDraw what you want on CAD or paper find the center point of the radius draw lines from the center point through the bend as many segments as you want then measure the angle of each line to the one next to it and that will tell you what angle each segment needs to be
Hope that makes sense I've confused myself writing it
Just for the sake of putting another spin on it - weld a cap on one end, pack with sand, weld a cap on the other end, heat & bend, remove caps.
Smarties tube.. And If you cock it up!....dam.. Just have to finish another tube of smarties ..Tin foil roll centres ( way higher quality) lol
Only Smarties have the answer.
If only there was a way of filtering forum replies to intelligent sober people.
