eSCHEn
Bit Wrangler
- SW Scotland
So you just freehanded it on the guillotine? Impressed if sothey were just marked out with dividers and cut to a line
Irrelevant for the job at hand but FWIW if you want/need to use a lathe to make accurate sheet metal circles/holes/annular rings..
if u have a lathe u will have a faceplate . why mess about with tape taking chuck jaws out and using a tailstock center when u just use the wooden sacrificial disk and screw your plate on and then part it off . no chance of it coming of if u get a dig in and its fast
and finish off with a half round filewell get cutting by hand if u have one the exercise will do u good
That's a bummer, I've just fired up the Bessemer!ok boys call it a day, put the over burden back. They think theres a better way than mining the ore, ya cant help some people even after you have moved 3000 yards of soil
first you need to buy a hemisphere and cut it in half, then hammer it flat, then cut out ya circle.....easy
Iron ore and other iron bearing materials, coke and limestone are charged into the furnace from the top blah blah blah...
AH but you did use a laser, you didn't think we would notice did you ?, I know coz I'm obsurvent .How coincidental is this then, had a call today could I make 12 off 3" x 1.5mm stainless discs to cap some barrier posts off, customer needed them straight away,
45 mins later had these on the bench, no lathes, laser cutters, plasma cutters, flycutters, or holesaws were involved,
