i first try to weld with 6010 but i had serius problem make a nice bed,i want suggestions in this,it was the first time with 6010 the rod was oerlikon zelcord 2.5mm and i tried them from 50 to 75 amps the welder was the esab in the picture & the problems was loootttt of spater uneven welds electrode keep stuck and extinguish...after ground &redo welds for 1 hour i used 6013 and everything was fine again
I'm not sure, you managed to upload them to your album ok, they just didn't appear in your post.
Glad they're the correct ones, they seemed the most appropriate ones from your captions.
If you want to link to any other photos from your album just right-click the image and choose 'copy image location' (that's what it's called in Firefox browser so it should be called something similar in other browsers), use this icon
and paste the image location into the text box making sure you overwrite or remove the existing http:// bit so as not to end up with it twice (such as http://http://www.mig-welding.co.uk/forum/images/editor/insertimage.gif) or the link will be damaged and the image won't be displayed as can be demonstrated if you click the link I put in the brackets.
