Kayos Gone...... Messages 9,046 Location Yorkshire Aug 13, 2015 #21 An end feed socket is the same thickness as pipe, the formers make it thinner IME end feed are more reliable than solder ring, especially in a tight spot
O optima21 Member Messages 4,358 Location halifax, England Aug 13, 2015 #22 if both pipes are steel, can't you just cut both pipes and weld them together? if you can't do that can you cut a slot in the 12mm pipe, expand it to 1/2" and then weld the slot backup.
D dannyp Member Messages 3,187 Aug 14, 2015 #23 pas pipes, just weld them togther, weld some 1/2 on the 12mm or make a sleeve that bothe will push in and baze it up
