bigegg
- Leeds, West Yorkshire
Am I correct in thinking that if I run, say, 10m of 3 core 6mm <edit:10mm> SWA to my shed DB(20A welder, 32A ring, 6A lighting MCBs) from the house DB (63A MCB), (actual load is likely to be <40A total - if i have the oven on at the same time as the plasma cutter, and compressor) then:
If I use the armour as an additional earth path, then I don't *have* to make it a TT install, as long as the Zs is within limits?
