TimeRich__
- Swindon England
View media item 9401View media item 9402View media item 9404Hi Guys, I'm hoping to get some advice on how to successfully weld a nut to a mullah'd Door Hinge Bolt in order to get it out; ahead of bracing the shell, then welding the bottom of the Door Pillar (cut out old & weld in new).
The Torx fitting in the bolt head is now useless and apart from needing to get the door off for the work, the bolt is also worn & causing play in the hinge so needs 'out' for that reason too. The other three bolts 'cracked' ok.
View media item 9403View media item 9404The way forward has gotta be to weld a nut to it, top or bottom*, but I can't find a way to clamp it up satisfactorily in order to do so. I' was hopeful that a G Clamp with a a short length of hollow tube 'bridging' the pointy end would 'do the trick' but the nut just falls off the moment I attempt to tighten it up.
Access is limited, so it appears its impossible to get a 'Tap' in there to put a thread on the exposed end & do it that way (anyone know of a Tap about the size of a Socket)?
*preferably bottom, but if I have to weld it at the top & then grind it off to get the pin out then so be it
NB: have I added a link to the photos OK?
