gaz1
- westyorkshire
has anyone come across this type of oil/fuel heater at all?
just got this up and running due to it being a duel fuel system hasn't been used in over 20 years so im told could be less time in years though
its grey and red with fan on top used within garages to either burn used oil or in this case gas oil
the control panel has a fuse to the left then a switch for heater off/on a mains light then a pump light
on the front it has an access cap to clean nozzle and a control knob to select either gas oil or higher setting for the heater I think
below this it has a drawer where you top up with oil or fuel
its based on this design but control panel is at front of unit same as the drawer
info ive found on net is this
0.03 MW net rated thermal input manufactured by Davair and identified as Davette 2
