Kinky John
Hello all,
I wonder if you can openly criticise my attempts at welding for quality and to see what i may be doing wrong or what i could try to do to improve upon them.
Ive been practising on and off over the last fortnight now. My machine is a SIP 130 Turbo Migmate.
I believe the metal is 1mm thick although it could be 1.2mm, im not sure i dont have calipers. Im using 0.6mm wire, Ar/Co2 gas.
After experimenting, ive got what i believe is a fair balance of power setting (low volts>medium or equivalent to 2nd lowest setting of 6) and wire speed to give a steady crackle. Getting a better result on this setting leads me to believe the metal is slightly thicker than 1mm.
On both pieces (below), the left hand weld is a lap weld and the one on the right is a butt weld.
Reverse:
All these are butt welds
Reverse:
My main question at the moment is about penetration. If you look at the reverse i cant get the weld all the way through. I seem to have reached a limit now in my ability as i cant successfuly improve on the examples above for penetration. Higher WFS and i get excessive spatter and hole buring if im not careful. Higher power and lower WFS and there is still what is clearly too firece an arc. Lowest power and higher WFS, i get a tall weld and no penetration at all.
At my present settings i feel i am getting a reasonably good shape on the welds (not too tall or flat) and i feel there is a good balance of settings. I am obviously still having problems seeing where im going and holding a straight line !
Ive tried from a stitching method (quick weld, quick pause etc) to running a weld for as long as i can.
From what iv been readin ive been wondering if perhaps the Ar/Co2 gas is cooling the weld off too quickly and would be interested to know what may happen with Co2 but ive ran out of that now.
Anyway, any tips would be welcomed at this stage,
Regards
Mark
Reverse:
Reverse:
Regards
Mark
