R ross_m Member Messages 66 Dec 27, 2013 #1 Is it possible to do the above? Im needing to prime the floor of my car which I stripped to bare metal. Im hoping I can use the u-pol acid etch aerosol and get the painter to finish with 2k top coat. Cheers Ross
V vdubz Member Messages 166 Dec 27, 2013 #2 Yes that would work, but if you want the job to last use some epoxy primer(brush or spray) if you need a good finish but don't have spray gear then these are good http://www.ebay.co.uk/itm/251381290...X:IT&_trksid=p3984.m1438.l2648#ht_2183wt_1091
A andeep Member Messages 238 Location Hertfordshire Dec 27, 2013 #3 If the floor isn't going to be seen, I would brush/roller some Lechler 2K primer on.
Chickenjohn Morris Minor and Porsche 944 fan Messages 1,284 Location East Kent Dec 28, 2013 #4 Yes, it will be fine. Won't be the best finish but as the floor will be under carpets/ sound deadening then that will be fine.
steveo3002 Member Messages 7,254 Dec 28, 2013 #5 yes ,no problems alot of bodyshops will use a rattle can to spot prime odds n ends
