Im stuck with a job thats got me beat.
Im trying to weld some shim plates,
imagine a cheese sandwich(stick with me here) you have thick bread either side of two thin slices of cheese and you need to stick them together but just along two edges.
The problem is that the cheese is melting out into a bob before it sticks to the bread.
In real life its 25mm plate 3mm plate and 1mm plate with another 25mm plate on top, the plates are in a stack and cant be changed around but all need to be welded together.
I have borrowed a
If it helps with setting advice.
GO.......
I have borrowed a
![thermal-arc-fabricator-330-ampere-halfautomaat.jpg](http://images.aanbod.be/gallery/447x340-0/302094/thermal-arc-fabricator-330-ampere-halfautomaat.jpg)
GO.......
