I didn't think of that. I'll give it a try later.if your spring has sheared near the tang? can you just bend it a bit and make a new tang for it?? common failure point on rotary return springs on pillar drills.....
rescued many a quill return spring this way as long as its not gone too far??
That was another think I was going to ask, how do I remove the quill? The bearings don't feel too smooth so I wanted to have a look at them, clean them and replace if they're too far gone.If it's a spiral torsion spring you may be able to buy a length of the material, remove the quill and use the star wheel to wind the spring.
This worked perfectly.if your spring has sheared near the tang? can you just bend it a bit and make a new tang for it?? common failure point on rotary return springs on pillar drills.....
This worked too, thanks.depending on what you got...................................pull the pinion out, the quill should then come out the bottom easily
