DAPPH
as dyslexik as I'm daft
Ive been looking for a reasonable degree indicator disc that I can put on/in the rear end of the head stock shaft so that after putting a slotted pointer that you read the indication through somewhere on the body of the lathe so I can actually mark off individual and half degrees at the chuck or face plate end. As well as make some sort of accurate jig for grinding lathe cutter tips & sharpening small drills correctly .
There were many websites where I could print off a paper disc and paste it on some hard board etc. but I found that the distances in between all the degree markings were not fully accurate as things changed ever so slightly as it comes off my printer .
Most of the discs I've seen were paper or expensive aluminium ones for car engine timing or motorcycle engine timing , mainly from the USA.
eBay item 400942905918 seems good , as it is in plastic & wipe clean
If it is OK I hope to make an even bigger disc out of aluminium at say a 10 " dia so that I can play at making some accurate cogs and make an indexing head .
