Hi all,
I'm looking to source heavy duty adjustable feet. They're to support & adjust 5m of very heavy workshop bench that I'm building for a client.
The bench will have vices mounted so there'll be dynamic loads transmitted down to the feet.
The 5m is sort of modular; made up of three individual benches bolted together under a continuous top. So I need 12 feet.
The floor it's all sitting on is +- 20mm at different points along it's length.
The legs are 80x40x4 but that could be adjusted if the perfect solution presents.
I'm thinking that the usual bolts with a pad on wouldn't be suitable. I've used them many times on other stuff but feel that the threads would soon suffer in this application.
Plan B is to pack the bottom of each leg with shims. It'll work fine but I'd rather find the adjustables.
I know I've seen relatively large section tubular adjusters for machines somewhere but can't find them.
looking forward to any suggestions you may all have. Thanks
