RaceDiagnostics
Tell me what I should do not what I can't do.You won't weld 3mm stainless to rusted steel 0.5mm thick.
That's whatThe next problem is the MOT man fails it because he thinks you've gutted the cat.
The perfect example of Schrodinger cat
Apologies, oh me of little faith.Tell me what I should do not what I can't do.
To be fair, that's not a bad repair given it was in situ and using less than optimal repair plateCut out and bent into shape.
A few mm of overlap.
Well I got a bit of burn through, should have cut out a bit more, ended up building up weld to close the hole. That will do for now till I can sort out a more permanent solution.
