Got given a SIP 150 migmate which I have done the wire feed power supply mod on and finally had a play around with.
I've got some 1mm and 3mm scrap.
Had some ok results on the 1mm (I think?!), these are some butt welds (Front and rear) Machine is on its lowest for this and I couldn't hang around!
Then tried the 3mm, machine on max I didn't really get any penetration (on plate, no joins).
Should this machine be able to weld 3mm without too much grief
Also I often had a little ball on the end of the wire. is this normal or a sign of poor settings
