Memmeddu
- Italia Sardegna
So since I'm in lockdown with absolutely nothing to do I was wondering about learning more about carbon arc brazing .
I've read various threads online about this technique but I didn't completely understand how it works
This thread would be meant to put together some knowledge about prior starting another thread in the projects section where I will cover the building of the torch .
So what I've understood is that a buzz box would be the preferred power source for this process , someone says that an inverter welder would work but AC is better in this case (heaven electrodes consumption)
Current settings way lower than carbon arc gouging so my little buzz box would be enough (200A)
But I can't understand which size of electrodes and current settings I would need to use (heating stuff for bending)
Another thing I was reading about is eyes protection
Which shade I should use?
About this I'm thinking to get a traditional aulekro helmet (with double glasses and pc clear lenses inside)
Construction wise I'm searching out for various designs and trying to understand which one would be the best
The clamp holder design seems to be the easiest way to make a torch
This involves a kind of clamp that when is compressed will make the carbons touch together and start the arc
There is also the slide design
This involves to use a sliding element on the handle to adjust the distance between the tips of the carbon electrodes
Another design is the "Lincoln style?" I've seen Lincoln electric arc brazing torches online and those use a mechanism which turns the rod holders to adjust the distance between the rods
This design is the most complex but also the most elegant I might say
Heat shield useful or not?
I've seen some torches use a kind of heat shield between the Arc and the handle ,some others don't .
The rod holders
Various possibility here to make them
But what to use?
Copper isn't an option (too much expensive and hard to find here)
Alluminum tubing (I have some) but the parts that hold the electrode would be steel
So steel might be easier to work with , cheaper , and I can weld it .
Steel rods o steel tubing
Steel rods are easier to weld
Steel tubing I could put the copper strands inside of it
So essentially a lot things in mind but actually not clue of how to proceed
I can buy one already made but where's the satisfaction to use something Made with your hands ?
Thanks in advance and sorry for the long thread object
The rod holders
But what to use?
