asg fabrications
hey people check out my new project woop woop
just brought this unfinish quad with a cbr900rr enigne conversion, he put the engine in and line it up pretty good for the chain on the back sproket but the welds are dog s**t and the tube cuts are the same and some of the joints are the same to take a look below....
this is the rear engine mount onto the frame am going to replace the bracket with somthink nice and chop the bit of the frame and tig a new bit back on.
this is the L/H bottom brace which needs a throwing away and cutting the 2 tubes he welded together out and doing a nice neat job, i want this bar to be bolted on so i can get the enigne in and out any ideas on what sort of mounts i could use?? rose joints maybe?
this is the R/H bottom brace but hes welded the front to the 2 tubes but am going to throw this bit away and want to do the same as the other side.
am going to widen the tubes that go over the carbs slightly here just so i can take them on/off easyer and fit the air box on or maybe put some pipercross socks over the trumpits.
front of the quad he also put the braces at the top witch also need cutting of and then notching some new tube and tiging back on...
after ive done this am going the seam weld the whole frame where poss and maybe gauset a few places as well then send it on for sand blast and powder coat.
am just strugling for ideas on them two bottom bars i want to bolt on/off what could i use?? pics or links would be good
cheers
cheers
