Workshop questions
  1. Wozza317
    Wozza317 New Member
    45
    Manchester
    Hi hope this is in the right place.
    I have had a workshop built 12x12 and with sectional concrete panels
    Should I paint the floor or leave it as it is ? just wondering if there would be any risk while welding grinding etc.
    What would be the benefits of painting it against leaving as is?
    Should I clad the inside? (just wondering about fire risks)
    Does anybody else have a sectional concrete workshop and what issues have you come across if any.
    Sure I will have more questions once the wiring has been done and I start using it properly.
  2. Wallace
    Wallace Member
    6,029
    Staines, Middlesex, England.
    Sealing and painting the floor will keep the concrete dust at bay and makes sweeping up easier.
    8ob, Davek0974, Parm and 5 others like this.
  3. Wozza317
    Wozza317 New Member
    45
    Manchester
    Thanks mate
    Well I guess my next question would be what paint would be most suitable for a concrete floor in a workshop :)
  4. Wozza317
    Wozza317 New Member
    45
    Manchester
    Just found Leyland Anti slip floor paint, probably use that unless anybody can see any possible issues with it. :)
  5. Gritineye Forum Supporter
    916
    Sussex UK
    I sealed and painted my garage floor, expensive to do but it wasn't long before it all wore off except small areas around the walls and under benches.
    Not worth the trouble if you use trolley jacks, axle stands and such in my opinion, maybe OK in a machine shop with just foot traffic.
    I often see worn off floor paint in other garage/workshops and in pictures posted on here and other forums.
    anto44 and gt6s like this.
  6. Burdekin
    Burdekin Chief Bodger
    4,470
    Aberdeen
    Parm, Hopefuldave and Wozza317 like this.
  7. 500e
    500e Always buy fire insurance a flood is hard to start
    3,617
    Somerset UK
  8. Wozza317
    Wozza317 New Member
    45
    Manchester
    I think the epoxy is where I will go.
    Just need to give the concrete a few more weeks curing time to make sure the moisture is as low as possible.
    Thanks guys
    cocker and Burdekin like this.
  9. Ashley Burton
    Ashley Burton Member
    2,189
    Northamptonhire
    Rubber floor mats here!
    123hotchef likes this.
  10. Tinbasherdan
    Tinbasherdan Metal mangler
    4,297
    Bolton, England
    I painted my garage floor and it lasted about 30 seconds!
    skotl and 123hotchef like this.
  11. Wozza317
    Wozza317 New Member
    45
    Manchester
    What paint did you use so I can avoid it :)
  12. Tinbasherdan
    4,297
    Bolton, England
    I believe it was leyland trade
    Wozza317 likes this.
  13. Wozza317
    Wozza317 New Member
    45
    Manchester
    Yes I looked at that and then compared the specs with epoxy 2 part paint, as i said epoxy is likely the way I will go.
    Hopefuldave likes this.
  14. Wozza317
    Wozza317 New Member
    45
    Manchester
    Sparky has just been around to survey the wiring requirements
    I will be having 3 x double 13a sockets, 1x 16a and 1x 32a socket plus 2 x led strip lights and approx 15 meters of 10mm armoured cable.
    He has not given me a specific price for all the work yet but from the way he was talking it might be around £500.
    I have used this lad before and he knows what he is doing so happy days.
    I will update with the exact cost when I get his quote.
  15. cheb Member
    137
    Outer Hebrides
    I've used Coo Var 2 part on my workshop floor and it's lasted well, about 20 years. The bits that haven't are because of mechanical damage.
    The shed has been done with International 2 part epoxy. Time will tell, it's only about a year old.
    Both floors were acid etched before the epoxy, the shed could have been drier, the finish is terrible. That and I applied with a sweeping brush.
  16. Wozza317
    Wozza317 New Member
    45
    Manchester
    As the floor is brand new and unpainted, stained or polished I guess I can do without acid etching and just clean , seal and paint ?
  17. cheb Member
    137
    Outer Hebrides
    Both of mine were new and unpainted. I still acid etched them, it doen't cost much and isn't going to make things worse.
  18. Wozza317
    Wozza317 New Member
    45
    Manchester
    Hmmm I guess your right wont do any harm to do it I suppose :cool:
  19. Hopefuldave Member
    711
    The Shed f Danger, surrey, England
    I've had 2 pack epoxy down for 5 years, it wears well except where it gets overloaded and the concrete underneath chips (2 tons of lathe touching down a bit firmly off the trailer ramps...)
    Dave H. (the other one)
  20. cocker
    cocker Member
    431
    lincs , England
    put a rubber backed carpet tile on the concrete floor .
    Pick it up after a couple of days and you will see how much water is still coming out .
    Repeat until you're happy
    Wallace and Wozza317 like this.
Advertisements
