wolfweld 135 wire feed speed fault
  1. leewesley20371 New Member
    2
    Bugle, Cornwall, UK
    Hi all, newbie here, I've recently purchased 2 welders one of which is a wolfweld. I went to use it toweld my car and I'm finding the wire speed knob isn't doing anything apart from full feed. What do I need to do to sort this fault out ? TIA
  2. leewesley20371 New Member
    2
    Bugle, Cornwall, UK
    Anyone ??
    I need to find out if it's worth changing the speed control knob or should I bin the whole thing ??
  3. Cobbler
    Cobbler Codger bodger
    5,037
    Gloucestershire UK
    I'm not sure that if you change the wire speed knob & potentiometer it will cure the fault, more likely it's a component on the printed circuit board. I can't help you as to what as I'm not savvy with electronics, but hopefully someone who is will be able to help.
  4. R Kraft Member
    970
    Wyoming,USA
    If you would post a photo of the pcb, it would give a better idea of what my be needed.
  5. bwservices Member
    397
    Ireland
    Or possibly a wire after coming off the pot/board.open circuit would put the wire speed at full
Advertisements
