Hi,
I have a Cigweld Transmig 200 (Australia).
I am having hassles with the wire speed adjustment - it just won't go slow enough, even when set to minimum. The potentiometer does work (kind of) the speed increases as I turn the knob, but at minimum it still races along way too fast. I've been using the machine for several years without issue, but this problem started happening with the last few uses. Initially it seemed to be an intermittent issue, but now seems to be a more consistent problem.
Does this sound like a problem with the pot? Thinking I should try replace that in the first instance and see if it makes any difference. Is there any way I can test the pot?
I'd appreciate any suggestions.
Thanks,
Jonty
Thanks,
Jonty
